An odd driveshaft question......
Old Feb 23, 2015 | 01:41 PM
Ramthatthing's Avatar
Ramthatthing
Default An odd driveshaft question......
Ok this is gonna be an odd question. So I have a 97 Dodge Ram 1500, 5.9, auto. It's extended cab. I'm swapping the auto out for a nv4500 and I beleive the 241 tcase. It's out of a 94 ram 2500 with the 5.9 gas motor. This truck is standard cab long bed. Now how in the *^#k do I get one of the trucks driveshafts to work. Do I get one cut down and is there a piece to convert the size difference?! Any help would be greatly appreciated.
Old Feb 23, 2015 | 02:47 PM
Measure the driveshafts, and compare lengths. Good chance they will be pretty close, then you just get the 'adapter' u-joint, if you use the 2500 shaft. I don't recall if the spline count was the same on the 231 and 241 t-case output shaft....
Old Feb 23, 2015 | 03:29 PM
Ham Bone's Avatar
Ham Bone
You should read this https://dodgeforum.com/forum/2nd-gen...al-swap-3.html
