engine code help
Old Feb 25, 2015 | 06:57 PM
2015ram's Avatar
2015ram
Default engine code help
i overhauled that 5.2 and everything works fine other than the check engine light is on,i put my scan tool on it and it says "engine coolant temperture circuit high input" put a new temp sensor in an stays the same....any ideas?
Old Feb 25, 2015 | 08:07 PM
Moparite's Avatar
Moparite
Did you reset the pcm(erase the code)?
Old Feb 25, 2015 | 08:17 PM
What year truck, and how many pins on the temp sensor?
Old Feb 25, 2015 | 08:42 PM
2015ram's Avatar
2015ram
i erased the code an it comes back on,its a 1999 2 pin
Old Feb 25, 2015 | 08:48 PM
Ok, you only have one sensor then.
Check voltage on the pins, see what you get.
