Cam Question...ya I know great...another one
Old Mar 11, 2015 | 11:04 PM
snowboundrmk's Avatar
snowboundrmk
Originally Posted by beeker
Can of worms is right, cause you need adjustable roller rockers with a cam install, thats another $430, and don't forget hardened pushrods and guideplates. With a cam install stick with 1.6 ratio rockers, let the cam do the lifting. My cam install is still not running great, think it's the lack of a custom tune but one step at a time.
You don't need adjustable rockers with a cam, just the correct length pushrods which is usually stock length. And you don't need guidplates with harland sharp rockers which then means you don't need hardened pushrods.
Old Mar 12, 2015 | 12:01 AM
beeker's Avatar
beeker
Thanks for the correction. Think my cam was an odd one cause I ordered it to match my 1.7s instead of getting rockers to match the cam.
The 1.7s are 3/8ths pedestal mount, the rocker studs that come with are 3/8ths on the rocker side and 5/16ths into the head, direct fit. Stock valve covers have good clearance, fine unless you get the adjustable rockers. In that case you'd modify your valve covers or get taller ones.
Old Mar 12, 2015 | 12:11 AM
Big Joe C's Avatar
Big Joe C
Straight from Harland Sharp: * Harland Sharp original series, pedestal mount, Dodge 5.2/5.9 Magnum V8, roller rockers are designed to be a replacement for the factory rocker that fits under the stock valve cover.
* Simply remove the factory rockers and rocker stands and replace with your new Harland Sharp roller rockers. We recommend always checking for head & valve cover clearance and proper lifter preload.
* The non-adjustable rockers are designed to the factory specs. If you change camshafts or machine the heads, you will have to correct your pushrod length. Always check before installing. We recommend them only to be used for serious racing applications.
Old Mar 12, 2015 | 12:19 AM
beeker's Avatar
beeker
The kit comes with everything you need, it fits.
Old Mar 12, 2015 | 01:48 PM
Big Joe C's Avatar
Big Joe C
Yep and a buddy of mine can get it from his parts guy with $100 off.
Old Mar 14, 2015 | 12:16 PM
dodgeram07's Avatar
dodgeram07
get the 1.7 rockers,, 5.2 cam has more lift than a 5.9 cam in years ago resesch it was like .432/.432 lift then put the 1.7 ratio on that Its around the same as the cam swap,, 1.7 will change the Duration also by a hair on the mouth of degs the intake and exhaust are open
if you where going to cam RT cam which lift is like 510? ish , but like said rockers will be close
but **** cam and springs and a tune bah bah bah ,,,, just get rockers
Old Mar 14, 2015 | 07:29 PM
Big Joe C's Avatar
Big Joe C
Yep I don't want cam headaches. I'm stickin with 1.7s and an sct tune
Old Mar 15, 2015 | 09:53 AM
Spillage's Avatar
Spillage
Yup... I have stock 5.2 noted as .270"/.270" lobe lift and .432"/.432" valve lift (1.6 rockers).
With 1.7 rockers you should be .459"/.459" valve lift.
Old Mar 23, 2015 | 11:00 PM
tweeker909's Avatar
tweeker909
Why would you need to pull the heads? Intake would have to come off to do the cam, that I will certainly agree with..... I am also curious why hughes would want you to replace your lifters... not like theirs are any different. Valve springs and such, yeah, I could believe that too, depending on cam selection. You will probably run into most of that no matter what cam you choose though...... Not to mention, the custom tune it may require. (another 500 bucks.) May want to just sit on the money, build up a bigger pile, and do that when you rebuild the motor.
stock lifters can not take the heavier valve springs that are required with the smallest of cams..they will collapse under the higher valvespring rate.
Old Mar 24, 2015 | 07:06 PM
What are you basing that on?
