"GEN" light on
Old Mar 21, 2015 | 02:00 PM
Rafarre91's Avatar
Rafarre91
Default "GEN" light on
I have a 1997 dodge ram 1500 5.2 4x4. I had to pull the transmission pan to replace the filter and seal as it was leaking. I bolted it back up and started to take it for a drive, as I was driving the truck shut off and came to a complete stop. The "GEN" light came on and now it will only crank but I can't get it to fire. I've had the alternator tested and it's a brand new battery. I'm lost and I have no clue where I could start from. Can anybody help me?
Old Mar 21, 2015 | 02:13 PM
You have more than one problem, make it run first. See what's missing, fuel, or spark.
Old Mar 21, 2015 | 02:26 PM
Rafarre91's Avatar
Rafarre91
It's definently getting fuel, the voltage meter only runs up to around 12 volts when I turn the key on
Old Mar 21, 2015 | 06:26 PM
That's only reading battery voltage. It won't charge till the PCM thinks the engine is actually running.
Are you getting spark?
Old Mar 22, 2015 | 12:21 AM
BrandonBuc'em's Avatar
BrandonBuc'em
i had a gen light issue once upon a time. after hours and hours of looking for what the hell is wrong. i noticed the spark plug wire had become loose enough to be resting against the exhaust manifold. it was grounding out on the manifold. zip tied the wire away and it fired right up. check it out man. hope this helps
Old Mar 22, 2015 | 08:45 AM
Rafarre91's Avatar
Rafarre91
Thanks guys I'll check it out! I'm not to sure if it is getting spark so I'll definently take a look at this. I hope it's one of my problems
Old Mar 22, 2015 | 12:10 PM
Moparite's Avatar
Moparite
If the engine stops all the idiot lights come on not just the gen. Check if you are getting a spark.
Old Mar 22, 2015 | 05:34 PM
Rafarre91's Avatar
Rafarre91
Thanks for y'all's help, it turned out to be a fusible link that was blown.
