Water in transmission .
Old Apr 5, 2015 | 01:25 PM
Moparite's Avatar
Moparite
You need to replace the radiator or if you want to cheap out on it buy an external radiator cooler put plugs in the fittings where the lines connect at and run it that way. You still need to flush your tranny and replace the filter.
X2!!!
Old Apr 5, 2015 | 03:17 PM
ericluck's Avatar
ericluck
I already got a new radiator but i was thinking since i saw the o ring that keeps the water out of the transmission fluid tank was seated wrong and had a crease in it that it might be the problem. The radiator is less than 2 years old and i bought it from NAPA and it has a guarantee i though i might have found the issue. I will never cheap out on a repair that could cost more in the long run. But that bypass was the first thing that was ever mentioned to me. I figure the tank is there for a reason and my transmission is kind of important .Ha . Anyway thanks for the words of advice. i'll let you know if Napa honors the guarantee.
Old Apr 7, 2015 | 01:02 AM
horatio102's Avatar
horatio102
Water and transmission clutches aren't a good mix. I'd plan on it not hanging in there much longer.
Typically the transmission cooler is a coil of tube in the radiator tank. There will be seals to keep the coolant IN the radiator, and trans fluid in the pipe.
I would disconnect the trans cooler lines from the radiator, let them drain out, and then pressure test the radiator. If coolant pours out the cooler fittings, there's a leak internally. Replace it.
Old Apr 15, 2015 | 08:59 PM
ericluck's Avatar
ericluck
Default Water logged tranny.
Well Gentlemen I think she's toast. I finally had a chance to pull the pan and found metal shavings, water&tranny fluid mixture, unidentified pieces of steel,and a bunch of soot. Looks like clutch powder. Would someone tell me what these pieces are?
Old Apr 15, 2015 | 09:00 PM
UnregisteredUser's Avatar
UnregisteredUser
That's the infamous broken overdrive snap ring.
Old Apr 15, 2015 | 09:01 PM
ericluck's Avatar
ericluck
Default Dumb me
I forgot to mention the penny was not i repeat Not in my pan! Oh never mind i forgot i wasn't on facebook. jk Thanks
Old Apr 15, 2015 | 09:07 PM
ericluck's Avatar
ericluck
Default Over drive ring
Man you'r quick. Thanks . Now time to plan on what t next.If parts are falling off i'd say she's not looking to good. I'll be spending some time reading again.
Old Apr 15, 2015 | 09:17 PM
UnregisteredUser
You're welcome.
I've just gotta say it to keep my streak alive: Dude, you want a Mega Viper!
Old Apr 16, 2015 | 12:46 AM
horatio102's Avatar
horatio102
I like building things myself... but that's just me.
Old Apr 16, 2015 | 08:37 AM
Moparite's Avatar
Moparite
You need a press to compress the od spring so you can remove/install a new one. You can just pull of the od unit off the back of the trans so you don't need to remove the whole thing.
