Audio Help
Old Mar 29, 2015 | 09:34 AM
Bosgarage57's Avatar
Bosgarage57
Default Audio Help
So I was hooking up my backup camera, decided to use the radio (aftermarket) as my power/ground. I must have done something wrong because now my radio doesn't work . I've checked all the fuses inside and out, the fuse on the radio as well. I am not getting power to my yellow (constant) and black (ground). any suggestions?
Old Mar 29, 2015 | 10:05 AM
Answered in the audio section. No need for two threads. Which one do you want to leave open?
Old Mar 29, 2015 | 10:25 AM
Bosgarage57
Sorry for the double, didn't know there was a specific audio section. Guess this one since the other one is closed.
Back on topic. I have put everything back to the way it was, but still no go. I still feel it has to be a fuse as well, but I have checked all of them.
Old Mar 29, 2015 | 10:40 AM
Both fuse boxes? One under the hood too?
Old Mar 29, 2015 | 10:43 AM
Bosgarage57
yup, fuse behind head unit, fuses at side of instrument cluster, and fuses under hood.
I have power on the red wire (ignition) but I didn't mess with it. I wonder if theres an inline fuse on the constant somewhere I cant see.
Old Mar 29, 2015 | 12:43 PM
I would look for the inline fuse. That was my first thought.
Old Mar 29, 2015 | 03:43 PM
Bosgarage57
Is there an inline fuse that dodge originally put in it somewhere?
Old Mar 31, 2015 | 12:07 PM
Bosgarage57
Just want to update. Issue has been fixed
I noticed last night as it was getting dark that my interior lights werent working. I started googling and found out both the radio and lights use the I.O.D. fuse in the cab. I checked it and it was blown.
Thanks everyone for your suggestions.
Old Mar 31, 2015 | 12:38 PM
Thought you checked all the fuses inside and out??
Old Mar 31, 2015 | 12:44 PM
Bosgarage57
Right, typical newb :-) it should be labelled "hey idiot, check this fuse if your radio doesn't work". Who the heck knows what an iod fuse is! And after fighting 5 minutes with pliers I finally got the black platic off it to check it :-)
Again, thanks for your help and patience.
