Height of different springs
Old Mar 30, 2015 | 04:52 AM
slice0flime's Avatar
slice0flime
Default Height of different springs
Hey all, doing a bit of work on my truck, which is a 95 V6 2wd, and I've got a couple questions.
First, I believe there's a height difference between 1500 V8 springs and 2500 diesel springs. Does anyone know that height difference and if these springs are interchangeable?
Second, I'm curious if there is a height difference between V6 springs and V8 springs and also how much.
Hopefully someone knows a bit about this topic.
Cheers.
Old Mar 30, 2015 | 07:50 AM
Spring swapping for a little bit of lift is actually quite common on these trucks. If you grab springs from a 2wd truck, they should just drop right in. Keep in mind though, that going from a v-6 spring, to a diesel spring will indeed give you 2-3"s of lift, but, it will also ride MUCH stiffer.
Old Mar 30, 2015 | 09:36 AM
slice0flime
Perfect, that's exactly what I needed to know.
Appreciate it.
