No power
Old Oct 29, 2005 | 10:50 PM
Socha_62's Avatar
Socha_62
Default No power
Maybe its just me, but I think my truck should have more power than it does. It has the 318 in it and a Magnaflow system. Air filter, cat, exhaust is all new with in 4000 miles. Today I was screwing around and I put it to the floor while I was turning a corner from a dead stop and the rear wheels didn't even break loose at all.
Something else I'm missing or is this about all the power its got?
Old Oct 29, 2005 | 11:15 PM
Tani1500's Avatar
Tani1500
Default RE: No power
wow, 4000 miles, thats things mint. I think it should have more power. I can spin my tires in second. you have a auto or a stick.
Old Oct 30, 2005 | 12:46 AM
1500sport's Avatar
1500sport
ORIGINAL: Socha_62
With a 318, depending on gears it may not spin em. I have a 360 with 3.55 gears and with stock tires it wouldn't spin them straight line taking off at all. It would do it though going around a corner. I would think if you floored it going round a corner it should have spun a little.
Old Oct 30, 2005 | 01:40 AM
The Burning Rom's Avatar
The Burning Rom
There are a few times when I haven't been able to spin my wheels either [8D]
It's a 318...it's not built for raw power. It's built more for steady reliable power...a workhorse motor.
And as was mentioned, gears will make a difference.
Old Oct 30, 2005 | 01:47 AM
Socha_62's Avatar
Socha_62
3.92 gears, and it was going around a corner like I said Its an Auto. Maybe its just me, but seems like I should have a bit more.
Old Oct 30, 2005 | 03:31 AM
2big2dodge's Avatar
2big2dodge
you should have more power. i have a 01 ram 1500 4x4, 318, 3.92 posi read end. and i can get it to spin whenever i want really, no matter if its power stallin or turnin...
Old Oct 30, 2005 | 03:32 AM
2big2dodge's Avatar
2big2dodge
and also thats doin it with mud terrain tires.
Old Oct 30, 2005 | 12:29 PM
steve05ram360's Avatar
steve05ram360
one question not asked... how is your exhaust setup? if you have a new cat back setup with 2.5" dual out's that's most likely contributing to your low end power loss... spinning the tires with 3.90 gears should be easy. the last time I tried, from a dead stop I was able to "scratch" about 20' from a dead stop with BFG AT 285's that were about 80% worn, (still had good tread left) and posi in the rear. earlier in the year when I put on the dual exhaust with 2.5"'s on the output, I couldnt launch for the life of me. had them reduced down to 2.25" and a lot of low end torque came back.
Old Oct 31, 2005 | 09:38 PM
Socha_62's Avatar
Socha_62
I have an aftermarket cat thats the same as the factory one. So its a dual in, single out cat. Its one pipe for about 2 feet then it goes into my Magnaflow single in dual out.
Spin them from a dead stop? HA! That almost makes me laugh, I don't even think I come close to that! Seems like something else is wrong. Or maybe I am loosing that much torque? Oh yeah the pipes are 2.5" if I remember right
I have a tool box in the back also with probably like 60-70 lbs of crap in it. Is that weight really giving me that much more traction so I can't spin 'em?
Old Oct 31, 2005 | 09:54 PM
steve05ram360
take those 2.5" dual outs down to 2.25" and then give it a try. I had a simiar setup to yours when I 1st put my exhaust on and couldnt get out of my own way for the life of me... brought the out's down to 2.25" and you couldnt keep the sheet ars grin off my face... [sm=gears.gif]
do it!
