Engine drowning in fuel
Old 04-03-2015, 09:04 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,282 Likes on 3,029 Posts
Champions really don't like to work after they have been fuel fouled...... (in my experience.)
Check the coolant temp sensor just to the drivers side of the thermostat housing. If you have A/C, it's a pain to see/get to...... should be a two wire connector. Make sure everything looks good there.
Old 04-17-2015, 11:32 PM
jrcobb1994's Avatar
jrcobb1994
jrcobb1994 is offline
I have replaced the coolant sensor and i also updated my first post with more information
Old 04-18-2015, 12:03 AM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
I hate to say it, but you're putting crap (Duralast) parts on that truck so the fact that the part is new does not rule out the possibility of it being failed. Especially when it comes to the oxygen sensors.
Old 04-18-2015, 04:22 AM
jrcobb1994's Avatar
jrcobb1994
Bosch is the O2 sensor, and i did just read a post from an old thread about these trucks not liking cheap after market sensors in key areas, cam crank ect..
Old 04-18-2015, 09:03 AM
Moparite's Avatar
Moparite
Moparite is offline
You can add Bosh 02's to the list also, They don't last long. For 02's get NTK for sensors you cant go wrong with Delphi. Plugs stick with autolites. i have seen many posts on part brands and these seem to be the best. At least in my opinion, It's what i use in my trucks.
Quick Reply: Engine drowning in fuel
