stock suspension
Old Apr 8, 2015 | 08:55 PM
timallen's Avatar
timallen
Default stock suspension
How big of tires can I fit on a 97 ram 1500 318 4x4 and will it increases fuel milage like I'm thinking
Old Apr 8, 2015 | 09:54 PM
jsmith1969's Avatar
jsmith1969
I've got 305/70/16 on stock suspension but they do rub slightly at full lock, max without any rubbing is probably 285s.
Old Apr 8, 2015 | 09:58 PM
Bigger tires will not increase your fuel mileage.
Old Apr 8, 2015 | 10:18 PM
AtomicDog's Avatar
AtomicDog
285/75/16 is about as large as you can go without the tire rubbing something. Larger tires will typically rob you of your current gas mileage.
Old Apr 9, 2015 | 04:00 PM
timallen's Avatar
timallen
Default re
I figured as low geared as the truck is as long as I don't jump off the line it would increase my wheel speed at a lower rpm
Old Apr 9, 2015 | 05:16 PM
Ham Bone's Avatar
Ham Bone
It will. But there is greater mass in the tire and takes more energy to roll. Great rolling restinace. Also you are raising the brick higher In the air and not hellping the aerodynamic aspect any lol
Old Apr 9, 2015 | 07:29 PM
If you do better than 70% freeway driving, you *might* see a small improvement. Otherwise, ain't gonna happen, you will see economy drop.
Old Apr 13, 2015 | 10:26 PM
BigGreenRam's Avatar
BigGreenRam
Yep he's so right that's why I have a dakota with a 3.9 sips fuel not gulps like the 5.9 with 33s
But you can't cry about how much fuel it takes to drive if u drive a big truck
Old Apr 14, 2015 | 09:48 PM
BrandonBuc'em's Avatar
BrandonBuc'em
i have the same year, i put 295 on stock suspension and they rubbed really bad on the upper arm not even lock to lock. i 90 degree turn and they would rub. i had to buy 2 inch spacers. hub spacers are illegal in just about every state so this is not a permanent fix
Old Apr 15, 2015 | 01:57 PM
BigGreenRam
Your signature states u have a 5 inch BDS lift why u useing a spacer your going to kill your hub bearings what offset is your wheels
