1994 Dodge Ram 1500 4x4 Black Smoke
Old Apr 9, 2015 | 09:57 PM
bub80z28's Avatar
bub80z28
Default 1994 Dodge Ram 1500 4x4 Black Smoke
Blows black smoke wont pass smog. Eats the gas up!! Transmission will make the truck shake at 55 mph so have to turn off overdrive. Would that cause a problem? Truck would die after 15 miles of driving put new crankshaft position sensor seemed to help. Have put on new plugs wires rotor cap camshaft position sensor idle air control sensor throttle position sensor. Has 210,000 miles new heads 50,000 miles ago. Trying to get rid of black smoke to pass smog need ideas
Old Apr 9, 2015 | 10:54 PM
UnregisteredUser's Avatar
UnregisteredUser
Sounds a lot like a sticky/stuck injector. Determining which is left as an exercise to the reader.
Old Apr 10, 2015 | 08:52 AM
Bad O2 sensor?
Old Apr 10, 2015 | 09:08 AM
Shaking is due to a miss. Black smoke is running rich. And no, that won't pass emissions.
You have more than one problem going on there.
How old are the cap/rotor/plugs/wires?
Old Apr 11, 2015 | 07:26 AM
onegoodmason's Avatar
onegoodmason
X2 .
-unburned gas = black smoke
-stuck injector = gas eater
-Shake in OD = too much fuel at low RPM drowning spark . OD off means 3rd gear and higher revs and ability to burn the fuel better .
Check oil for gas smell and change right away if detected
Check injectors for clicking with stethoscope if possible , if not , pull plugs and look for gas soaked or washed plugs .
Always use new injector o-ring seals if replacements are needed !
Old Apr 12, 2015 | 09:50 PM
bub80z28's Avatar
bub80z28
I took out and checked all the spark plugs they all have carbon but the number 7 cylinder was oily had a lot of build up
