Timing chain help and mod questions
Old Apr 12, 2015 | 12:33 PM
If you have the factory aux cooler, compare your new one, to the factory one. Install whichever one is BIGGER. No need for both.
Old Apr 12, 2015 | 07:28 PM
CoryVolkenant's Avatar
CoryVolkenant
Ok got timing gears and all new cooling system with a 180 stat in runs about 184.6 down the highway seems to have a little more pep also but for now that stuff is done gear install will start tomorrow
Old Apr 28, 2015 | 07:53 PM
CoryVolkenant
well got the gears installed and drives so much better very happy with them, only thing now is the truck seems to shift a bit harder/firmer? normal?
Old Apr 28, 2015 | 08:00 PM
its running better, so, might just be normal. So long as it isn't harsh, smile, and enjoy it.
Old May 2, 2015 | 10:02 AM
CoryVolkenant
i think im going to adjust the bands any tips?
Old May 2, 2015 | 10:07 AM
Make sure you have an ACCURATE torque wrench.
Old May 2, 2015 | 11:56 AM
Moparite's Avatar
Moparite
An inch pound one not foot pound!
Old May 3, 2015 | 02:19 PM
beeker's Avatar
beeker
You are going to need a 8mm (or 5/16ths) square socket for the adjustment, not going to find that in a store.
http://www.ebay.com/itm/Grey-Pneumatic-1010FP-3-8in-Drive-x-5-16in-Square-Female-Pipe-Plug-Socket-New-/331518192875?hash=item4d30062ceb&item=331518192875&vxp=mtr
-Also need a 8mm open end wrench
-A 3/8ths drive T40 socket
-A deep 3/4 socket
-An inch pound torque wrench as mentioned.
I like the way this youtube guy does it on his 727, keep in mind our adjustment is slightly different
