Speedometer / Odometer inop?
Old Apr 12, 2015 | 12:59 PM
Watana's Avatar
Watana
Default Speedometer / Odometer inop?
I Have a 1997 Ram 1500 4x4, 5.9 liter, automatic. The speedo and odometer do not work. I installed a new speedometer sensor but did not correct the issue. Anyone out there having good advice on what to do next would be greatly appreciated.
Thanks to all replies!
Watana..
Old Apr 12, 2015 | 02:30 PM
Check engine lite on? Trans shift ok?
Old Apr 13, 2015 | 08:12 AM
peterparker3169's Avatar
peterparker3169
Watana..
It would be the rear sensor. Just did mine. Bought the truck a week ago n the guy was to lazy to do. Took about 20 min to replace. 30 bucks at O'Reilly
Old Apr 13, 2015 | 08:49 AM
97 and older trucks have the VSS on the output tailhousing of the trans, or t-case. The sensor on the rear diff is only for ABS. That changed in 98.
Old Mar 29, 2023 | 10:50 AM
Chickendeluxe's Avatar
Chickendeluxe
Well....Pulled the VSS.....Seems like I have a 98 up output shaft with NO speedo gear splines.....
Will check output petter tomorrow with rear of truck on hill so it doesnt leak
Thought only the Torque converter and VB electonics were different.....
UGH
