1999 quad cab no power windows seatbelts locked
Old Apr 18, 2015 | 12:49 PM
69dz302z28's Avatar
69dz302z28
Default 1999 quad cab no power windows seatbelts locked
Question for any one that can help. Have a 99 ram 4x4 quad cab sport. the windows are inoperable as well as power door locks. windows are stuck in down position. Seat belts are locked as well. Checked fuses and circuit breakers, all are good Any Ideas???? Does the seat belt control module under the middle front seat have any thing to do with the power windows, locks, dome light etc.??????
Old Apr 18, 2015 | 01:43 PM
Windows and locks both get power from fuse 1 (50a) in the PDC. Check that one. PDC is the black box behind the battery, under the hood.
Old Apr 18, 2015 | 03:38 PM
69dz302z28's Avatar
69dz302z28
Fuse 1 checks out good snap on scanner show sctm fault hen checking air bag module when checking body control, just had a meesage stating module fault
Old Apr 18, 2015 | 03:39 PM
69dz302z28's Avatar
69dz302z28
i understand that the sctm is resposible for the seat belt issue, but does it have anything to do with the windows locks interior lights ???
Old Apr 18, 2015 | 03:41 PM
Nope. Nothing at all.
Did you check the IOD fuse? (Ignition off draw) It's under a little cover in the fuse block.
Does your radio remember what time it is? Etc?
