2nd gear just quit
Old Apr 25, 2015 | 11:13 PM
01RedRamOffRoad's Avatar
01RedRamOffRoad
Default 2nd gear just quit
Hi everyone have gotten a lot of answers to questions in the past on forums but the worst has finally happened and I'm torn on what to do so I have a 2001 dodge ram 1500 4x4 and it is my winter dd and about a month ago I drove to work about 6 miles with no problems n no problems really before either. I had put a bottle of Lucas tranny fixer in a couple days before n was a little overfull but when I left work that day I drove away and pulled out onto the street and it just never shifted to 2nd so I messed with it to make it home then drove it 5 miles to my garage to switch vehicles so whatever happened it was very sudden, unexpected, and I didn't keep driving on it. 1st, 3rd, n 4th work fine it just won't shift to 2nd unless I really make it then when in 2nd it has no power and feels like it slips. So what I am asking is really if anyone knows what could be wrong and if anyone thinks it is worth fixing or my other option is to buy a new tranny from monster transmission. Any answers are greatly appreciated really want to get my truck running again. Thx.
Old Apr 26, 2015 | 10:55 AM
What's your fluid look like?
Old Apr 26, 2015 | 03:44 PM
01RedRamOffRoad
Still was decently red was starting to lose its color and it doesn't have an burnt smell but after the Lucas it looks more red, it also has 143k I have driven about 30k no prior information looked clean shifted good, always knew these trannies were junky but for how what has happened I think it may be the governor pressure solenoid and sensor but I plan on keeping this truck forever and want to go the route of brand new warrantied tranny just to call it good but I feel I have a good if not decent one I can fix for cheap, I planned on buying new pan w/ plug, gasket, solenoid, sensor, filter, and fluid see what happens but I guess for all I know the tranny is shot.
Old Apr 26, 2015 | 08:59 PM
Unplug the 8 pin connector about half way back on the drivers side of the trans. Go for a drive. Keep in mind, you will have zero automatic function. You will have to start in first, and shift when appropriate. (and downshift too.) You will not have O/D, or TCC, so, don't go far. If it shifts good when you tell it to, into the gear you tell it to, then just replacing the electronics should fix it. If it doesn't..... well.... probably rebuild time.
