Help!!! 1997 ram 2500 360 lack of power
Old Apr 29, 2015 | 05:07 PM
PAwrestling#1's Avatar
PAwrestling#1
Is this a year you just turn key on and off 3 times to get codes
Old Apr 29, 2015 | 05:25 PM
https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Apr 29, 2015 | 07:30 PM
PAwrestling#1
code 12,21, then 56.
Old Apr 29, 2015 | 09:41 PM
21 O2 shorted, or not switching. If its original, replace it, reset PCM, drive it. See if anything improves.
Old Apr 30, 2015 | 06:21 AM
PAwrestling#1
So will this cause a lack of power? Or maybe I should say no power. I just feel that being how bad this is I should be going further in investigating but I guess replacing and driving it just a little won't hurt nothing. Maybe pull #8 plug like I read somewhere and see how bad that looks for a possible clogged converter.
Old Apr 30, 2015 | 06:49 AM
mda8569's Avatar
mda8569
Lots of little things can add up. Pulling #8 is a good idea, as well as a few others. Plugs will tell you alot about how its running.
Old Apr 30, 2015 | 07:52 AM
Seriously, try removing the front o2 sensor and see if performance improves. If not, then you at least rule out a clogged cat as the culprit.
Old Apr 30, 2015 | 09:05 AM
PAwrestling#1
Oh im doing all these things. Im not questioning anyones opinions or advice. Just trying to have a game plan and in what order for this weekend as I'm gonna be living on,under, and around this truck
Old Apr 30, 2015 | 06:05 PM
Gotcha. The first and easiest would be to inspect the plenum as stated in that thread. Everything could be the result of a blown plenum gasket.
Old Apr 30, 2015 | 08:20 PM
PAwrestling#1
i cant see down the throttle body good enough. Gonna have to get a mirror or take the TB off
