Help!!! 1997 ram 2500 360 lack of power
Old Apr 28, 2015 | 10:11 PM
PAwrestling#1's Avatar
PAwrestling#1
Default Help!!! 1997 ram 2500 360 lack of power
I just bought a 1997 ram 2500 360 4x4 auto with 207000 miles on it. Truck has a skyjacker 5.5 in lift, 3" body and 2.5" Susp. It has 315/75 R16's tires and it's a complete dog.. And i mean there's slight inclines around my house on parts of a main highway that i go a back way to avoid because it's a flatter backway. Now should I assume the engine is just tired and replace or is it the lift and tires, or plenum gasket,or???? It has dana 60's under it with 4.11 gears. I would think this should be snappy low end??
Please help or guide me
Old Apr 28, 2015 | 10:14 PM
PAwrestling#1
oh and the exhaust was replaced with a glasspack and a short tailpipe or downspout under the center of truck. Could it be a back pressure loss causing it to feel like a dog?
Old Apr 28, 2015 | 10:36 PM
Have you checked the plenum or checked for a clogged cat converter?
Old Apr 28, 2015 | 10:45 PM
PAwrestling#1
havent really checked anything yet. Only thing I can say it idles nice but just a dog. I just got this truck this past sat. and have been concentrating on getting the body parts it needs but this weekend wanna start troubleshooting the power issue. I know the plugs are way past due for change
Old Apr 29, 2015 | 07:22 AM
PAwrestling#1
WHats the best way to check the converters?
Old Apr 29, 2015 | 07:28 AM
Remove the front 02 sensor. Everything you need to know is in the plenum sticky.
Old Apr 29, 2015 | 07:55 AM
PAwrestling#1
how do I find that sticky
Old Apr 29, 2015 | 08:06 AM
It's called the "End-all, be-all plenum thread". First thread in this section. Right at the top. Or search "plenum".
Old Apr 29, 2015 | 09:19 AM
Moparite's Avatar
Moparite
With 207K if it's the oem converter it needs to be changed. Change plugs cap-rotor wires if needed. Check fuel pressure and compression. Do you have any codes?
Old Apr 29, 2015 | 09:55 AM
PAwrestling#1
Check engine light just came on last night so guessing I do
