multiple electrical issues
Old May 8, 2015 | 12:32 AM
moparjunky423's Avatar
moparjunky423
Default need help ASAP!!!!!!
I need help getting this fixed as soon as possible it's getting hot in Wyoming and I can't roll my windows down if anybody has had this issue or has any comments please comment!!!!!!!
Old May 8, 2015 | 08:53 AM
Moparite's Avatar
Moparite
My stereo hasn't quit working. is there a possibility that I get a bad ignition switch and it'd be a good idea to try different one just wondering? Came from auto douche bags
Does the stereo work with the key is on??? What works with the key on???? Anything??? Read my posts, You need to see if you have power(key on) to the fuses(in the cab). You will need a volt meter (preferably) or test light.
auto douche bags ??? WTF? Maybe a reputable parts store would be a start.
Old May 8, 2015 | 09:10 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Did you actually unplug your ignition switch at the column and look at the terminals yet?
Old May 10, 2015 | 09:20 PM
moparjunky423
The ignition switch came from auto zone , but was returned. Yes I have looked at every Plug . When the weather clears I plan on checking all grounds I can find
Old May 11, 2015 | 10:01 AM
Moparite's Avatar
Moparite
Power from the key switch goes to the fuses then to what they are for such as blower motor,windows etc. You need to find where you are loosing it at. Start at the switch connector and follow it to the "load" (blower motor,window motor etc...). You will need a wiring diagram and a meter.
Old May 11, 2015 | 10:14 AM
TNtech's Avatar
TNtech
(grounds) Something I've seen a ton of times is the dash brackets on both ends where it mounts to the body, behind the kick panels. People will do a heater core or evaporator and not tighten the large bolts down. That is a HUGE ground loss if that shakes around or isn't making good contact.
Old May 21, 2015 | 11:50 PM
moparjunky423
problem keeps on persisting now my mirrors dome light and radio do not work.I touched a test light to the ignition circle light thing and the radio mirrors and dome light quit working just recently
Old May 22, 2015 | 09:36 AM
Checked the IOD fuse?
Old May 28, 2015 | 10:35 AM
moparjunky423
Radio mirrors and dome like working again but all other issues listed are still present
Old May 28, 2015 | 12:03 PM
What's still not working? Had a chance to download the FSM yet?
