98 Ram 2500 5.9L 4x4: No O/D light at all.
Old May 6, 2015 | 02:09 PM
issakar's Avatar
issakar
Default 98 Ram 2500 5.9L 4x4: No O/D light at all.
I mentioned this in another thread. HeyYou posted a pic showing where the O/D light is. I checked a little while ago and I have no OD light at all, even at KOEO bulb check when you first turn the key. While driving if I hit the O/D switch on the gear selector, I don't really notice any difference in RPM/driving condition at all.
I don't drive the truck much, so I figure I may as well do some work on it while it's sitting. It's mostly for hauling materials for the house.
Old May 7, 2015 | 08:39 AM
Moparite's Avatar
Moparite
You need to be over 45 mph before the od will kick in. I believe the only time the od light comes on is when the od is off.
Old May 7, 2015 | 01:36 PM
issakar's Avatar
issakar
It should still come on during the bulb check, shouldn't it? When I hit the O/D off button on the gear select I don't notice any difference in RPM or driving, be it 45 or 70MPH.
Old May 7, 2015 | 02:59 PM
You can test the switch. All it does is send a voltage signal to the PCM, to tell it you don't want overdrive. PCM takes it from there. (dropping to third, and turning on the lite.)
Old May 7, 2015 | 05:40 PM
issakar's Avatar
issakar
Do you know of a good quick n dirty test for the switch off the top of your head? It's obv a momentary switch. Maybe the scan tool has a switch status? I noticed it does for my speed control switches in my caravan. I haven't hooked it up to the truck yet.
Old May 7, 2015 | 06:05 PM
That's interesting.... If it can test the cruise switches, it would make sense (yeah, I know.....) that you could test to O/D switch as well.
Either that, or just backprobe the output wire at the pcm.
Oops, looking at the wiring diagram.... the switch grounds a circuit..... check and see if you are getting any voltage on the Black/Light Green wire at Ground 200. (down at the base of the steering column.)
Old May 8, 2015 | 12:48 PM
issakar's Avatar
issakar
I'll try and give it a poke this weekend. Taking the truck about 10 miles down the road to snag a chicken coop. Have I mentioned how rad having the 8ft bed is?
