Power Wagon Wheels
Old May 7, 2015 | 04:42 PM
Tarrbaby's Avatar
Tarrbaby
Default Power Wagon Wheels
Hello...
I have searched and searched and searched. I have a set of 2005 Power Wagon wheels laying around,
Will these wheels fit on my 2000 Ram 2500 Diesel 2WD (without issues)? I have not got any complete answers.
Thanks....
MT
Old May 8, 2015 | 10:08 AM
According to what I find, they are the correct bolt pattern, however, they are also 6" backspacing...... which is going to stuff the wheels in pretty tight. If you have a 4x4, that is going to seriously compromise your turn radius...... tires will rub on the control arms for the front axle.
Old May 8, 2015 | 11:21 AM
Tarrbaby's Avatar
Tarrbaby
Hey You....
THANKS...
Any idea what my stock wheels backspace and offset are?
Old May 8, 2015 | 12:58 PM
Backspacing is 4.5 inch, I do believe, no clue what offset is. (but, that's not nearly as critical as backspacing.)
Old May 12, 2015 | 06:22 PM
Tarrbaby's Avatar
Tarrbaby
Actually these wheels fit fine, I will have to go to a 265/70-17 tire and put a leveling kit on front end.
I just put one on and it sits fine... I will check the front end..
Old May 12, 2015 | 06:23 PM
See how far you can turn your wheels before the tires hit something. Then, take the wheel off, and see how much further you can turn the wheel.......
