Oil Light on at Idle.......sometimes
Old May 21, 2015 | 03:06 PM
webhead68's Avatar
webhead68
Default Oil Light on at Idle.......sometimes
I noticed the other day that my oil light came on at idle. It went off as soon as i tapped the accelerator. The oil pressure gauge went up a bit and light went out too.
I checked the oil and it looked OK. This happened with an old VW Beetle I had and it led to the motor blowing down the road. I'm hoping this isn't the same thing.....
Anybody had this issue?
Old May 21, 2015 | 05:14 PM
Just about everyone. Oil pressure sensors are crap. Replace it, see if the problem goes away.
Old May 21, 2015 | 06:03 PM
ReadRam's Avatar
ReadRam
You may have a sludged up pick up tube and screen in oil pan, depending on prior maintenance. Only way to know for sure is to hook a mechanical gauge where pressure sensor lives or replace sensor and see if the problem persists,
