Ticking sound i cannot locate
Old Jun 5, 2015 | 06:21 PM
How do the joints look? Did the tire spin fairly easy? Didn't stick at any point?
Old Jun 5, 2015 | 10:03 PM
CPTAFW163's Avatar
CPTAFW163
when the front is jacked up (even one side at a time), take off the wheel and wiggle the U-joint with your fingers. See if it wiggles. Mine was ready to break loose if I didn't wiggle it myself.
Could be the centercaps of your rims (if you have them). I have that problem with my vehicle and I have to put a bead of RTV on the centercap rim to stop the problem...every 4 months!!!
If you have centercaps in your rims, it is probably them.
Old Jun 5, 2015 | 10:07 PM
BrandonZane's Avatar
BrandonZane
No center caps, it a solid rim (Only one piece), I didnt try taking the wheel off though just jacked it up and wiggled the tire a bit, i'll go try that.
Old Jun 5, 2015 | 10:08 PM
zildjian3707's Avatar
zildjian3707
I had a similar issue, turns out it was a blown header gasket
Old Jun 5, 2015 | 10:13 PM
BrandonZane
If i take it apart to check that, wouldnt i have to replace the gasket regardless?
Old Jun 5, 2015 | 11:54 PM
CPTAFW163's Avatar
CPTAFW163
you could seafoam the engine and see if white smoke comes out at the header/manifold area.
Old Jun 6, 2015 | 12:38 AM
zildjian3707
You'll know it's a header issue or big exhaust leak If you fire it up and it sounds like a Sherman tank
Old Jun 6, 2015 | 08:38 AM
Moparite's Avatar
Moparite
You dont have to lift the wheel to check the ujoints. Usually a visual inspection you will see there is an issue(no cap seal, red dust/rust, gap between the cap and cross=missing rollers). Just turn the wheel out and look at it from the front. If it passes the visual try moving the axle shaft/yoke.
Old Jun 8, 2015 | 11:18 PM
BrandonZane
U joints seem fine, did some better listening (sat in the bed an had a friend drive) and it sounds like it may be coming from more of the center to rear of the vehicle. It is also speed sensitive ( stops when I stop, continues and gets faster as speed Increases) which inclines me to believe it could be a somewhat serious issue?
Old Jun 9, 2015 | 09:14 AM
Ramman18's Avatar
Ramman18
U-joint in drive shaft.
