2001 dodge ram 1500 slt front and rear end issues
Old Jun 11, 2015 | 11:10 AM
jws123's Avatar
jws123
Default 2001 dodge ram 1500 slt front and rear end issues
I have a 2001 dodge ram 1500 slt with 75k miles on it i have a few problems with it when hitting the break or hitting a bump even when going around a turn and hitting the break you feel clunking in the steering wheel and petals it almost feels like the steering column is moving but its not... i replaced the ball joints and the breaks also a the big sway bar yet it still clunks.. the steering has no play in it at all also sometimes when i go around a turn the rear end vibrates the rear end bearings where done a year ago this only started happening a week ago any suggestions?
Old Jun 11, 2015 | 11:12 AM
Rock solid Ram steering fix.
Old Jun 11, 2015 | 11:24 AM
jws123's Avatar
jws123
ok will replace that next what about the rear end vibration when going around a turn?
Old Jun 11, 2015 | 12:42 PM
Do you have a limited slip rear? May just need to put the correct fluid in it.
Old Jun 11, 2015 | 01:36 PM
jws123's Avatar
jws123
Yes i have the limited slip i flushed it out and put limited slip oil in it when i did the bearings
Old Jun 11, 2015 | 01:37 PM
And it's still chattering? Wonder if it wasn't actually the correct fluid.....
Old Jun 11, 2015 | 02:21 PM
jws123's Avatar
jws123
I used this
http://www.autozone.com/greases-and-...z-/991558_0_0/
Old Jun 11, 2015 | 02:27 PM
jsmith1969's Avatar
jsmith1969
Old Jun 11, 2015 | 02:32 PM
Yeah, I think that's a good idea.
