Truck won't start
Old Jun 25, 2015 | 10:08 AM
PCM will engage ASD relay for a few seconds at initial key on, after that, if it doesn't see the engine turning, (crank sensor.....) it won't turn it back on. So, yes, I suspect your crank sensor is bad, or, for whatever reason, the PCM isn't seeing a signal from it.
Old Jun 28, 2015 | 08:11 AM
gibbo01ram2500's Avatar
gibbo01ram2500
So I replaced the crank sensor and now I have a new problem. It will fire off of starter fluid but it won run. The fuel pump is running when I turn the key on and I hear it running after I am done cranking the engine. I just replaced the entire fuel pump assembly so that is all new. Any ideas of what I should start looking at? I am guessing that I am not getting fuel now.
Old Jun 28, 2015 | 10:18 AM
Moparite's Avatar
Moparite
Try giving it some gas when cranking.
Old Jun 28, 2015 | 12:57 PM
gibbo01ram2500
Like pumping the throttle? Already did that. Nothing.
Old Jun 28, 2015 | 02:36 PM
Hold the throttle open just bit while cranking.
Old Jun 29, 2015 | 06:57 PM
gibbo01ram2500
Okay I tried that and I got a little sputter every now and then but not all the time and only when I start to crank the engine. Still will fire quickly off the starter fluid.
Old Jun 30, 2015 | 07:40 AM
Moparite's Avatar
Moparite
I would put fuel pressure gauge on it and see what kind of pressure you have. It will fire on the starting fluid so it's not an ignition problem.
Old Jul 1, 2015 | 05:12 PM
gibbo01ram2500
So I'm here working on the truck. Fuel pressure is 40psi before cranking engine. Try to start engine and the pressure drops to 0. Sputters but won't stay running. I still here the pump running after the engine dies or I stop cranking. Pressure rises back to 40. Please help quickly I would like to keep working on it.
Old Jul 1, 2015 | 06:46 PM
Think it's time for a new pump, if pressure drops off while cranking.
Old Jul 1, 2015 | 07:28 PM
gibbo01ram2500
Pump is new. Why would it produce pressure if it was bad?
