Distributor Timing/Install
Old Jun 14, 2015 | 04:56 PM
kxcrazy's Avatar
kxcrazy
Originally Posted by Wildman4x4nut
Well kxcrazy you're never going to find someone on here that might help you out unless you tell us where you're from. It is real easy to fill out your profile info and then it helps people by know what type of truck you have and where you are.
Duly noted and updated. I will post a new thread asking about the scanner.
Old Jun 14, 2015 | 05:53 PM
Eagleye134's Avatar
Eagleye134
Originally Posted by kxcrazy
I replaced my distributor and lined it up with tdc mark on balancer and rotor aligned with mark on distributor.
This got it to run and then I set fuel sync using the digital volt meter method to get 5 volt at switching point.
I know I should get it set with a scan tool but it runs good enough for now until I can either find someone with the tool that I can borrow or set it for me. I really do not want to pay the dealer to do this.
How exactly did you do it with the DVOM? I have one handy and have the AllData procedure for setting up the fuel sync that way, but just a lil advice couldnt hurt ya no.
Old Jun 14, 2015 | 10:57 PM
kxcrazy's Avatar
kxcrazy
It was actually very easy. Balancer at TDC then 17 degrees to the V8 mark.
Loosen distributor just enough that you can turn it with some effort.
Red wire from meter to the tan/yellow wire for the distributor pickup and black wire to negative on battery.
Key on and then turn distributor to find 5 volts. Took me a couple of tries to get it. Then tighten down distributor.
Old Jun 14, 2015 | 10:58 PM
You want to position the distributor to RIGHT where the voltage switches on.
Old Jul 10, 2015 | 03:36 AM
Eagleye134's Avatar
Eagleye134
What do you mean by "17 degreas to v8 mark" and do either of you guys know which pin is the Cam signal at the ECM ?
Old Jul 10, 2015 | 06:00 PM
kxcrazy's Avatar
kxcrazy
From TDC if you rotate the crankshaft 17 degrees you will end up at the v8 mark on the balancer and this is where you need to be in order to do the adjustment.
