New alt. not putting out enough volage, suspect other issues?
Old Jun 18, 2015 | 04:38 PM
  #21
monaco's Avatar
monaco
The inter-relationships between electrical devices on these trucks is sometimes quite mysterious...... Solve one problem at a time. Sometimes, fixing one problem, solves a whole bunch of others as well.
Got a volt/ohm meter? Could pull the relay, disconnect the a/c compressor, and then test the wire, see if it goes directly to ground.
Great idea - I was just thinking of that. I have no micro jumpers so I can't fully test the relay.
Old Jun 18, 2015 | 04:45 PM
  #22
monaco's Avatar
monaco
The wires connecting to the compressor are in pretty nice shape for the age.
Old Jun 18, 2015 | 05:52 PM
  #23
CTX's Avatar
CTX
Originally Posted by monaco
After. I'm fuzzy about the order of things but I'm fairly certain I got this issue when the battery first went dead.
HeyYou has a mass of knowledge re: these trucks so I am not saying don't try that - seriously.
Sounds as if you shorted something upon reconnection OR the battery or alternator are bad...circumstantial evidence is evidence of just that
Old Jun 19, 2015 | 08:17 AM
  #24
Moparite's Avatar
Moparite
Put a good fuse in, Disconnect the wire going to the compressor coil. Start the truck put the ac on. Then reconnect the compressor coil wire. If the fuse blows you found your problem. The compressor coil has a short.
Old Jun 19, 2015 | 08:54 PM
  #25
Pay attention to WHEN the fuse blows, if it goes as soon as the the a/c is turned on, even with the compressor disconnected, then its a wiring problem. If it blows when you plug in the compressor, time for a new compressor clutch.
