loose steering?
Old Jun 28, 2015 | 10:17 AM
peterbilt201's Avatar
peterbilt201
Default loose steering?
hey guys so need some help to know what all i should get to get my steering better. so driving down the road you gotta really stay with the steering and keep moving the steering wheel back and forth to keep the truck straight. makes me feel like cops may think im drunk driving. i dont get any bad vibrations or death wobble.
I was think about some type of new steering box and the dodge ram steering stabilizer but unsure after that.
Old Jun 28, 2015 | 10:42 AM
Moparite's Avatar
Moparite
Have all your front end components look at! Worn ball joints, drag link, tie rod ends and track bar are common.
Old Jun 28, 2015 | 11:40 AM
Ham Bone's Avatar
Ham Bone
Throw your steering stabilizer away
Old Sep 18, 2015 | 08:08 AM
shak's Avatar
shak
Here's a place to start...2nd gen's are notorious for weak/worn column bushing.
Open the hood...grab the steering shaft just below where it exits the column housing...try to move it left to right...up and down...in and out. Any play? lots of play?
Old Sep 26, 2015 | 11:39 AM
wv ram's Avatar
wv ram
while your checking the steering shaft check the intermediate shaft which goes to the steering box on mime the u joint the goes and the steering box was shot you feel the road , not being tight it wasn't bad everthing else I had went over and checked but rock auto is the best place to buy the shaft mine was $68.00 hope that helps
Old Sep 30, 2015 | 08:41 PM
ZeroZero3's Avatar
ZeroZero3
So like with all my projects, this one has also turned into a long term project.
I can't detect any play in the steering column bushing. The slip joint tho is loose the part of the shaft that enters the steering gearbox is also loose.
Any good fix for those two issue?
Old Sep 30, 2015 | 09:29 PM
ZeroZero3's Avatar
ZeroZero3
Old Oct 1, 2015 | 10:52 AM
There is an adjustment procedure for the steering box, that can eliminate a lot of the play.... may or may not get rid of all the slop in the box. If, after adjustment, the box is still more sloppy than you care for, only other option is replacement. On that, don't bother with the parts-store steering boxes. You may end up with one that is worse than what you have now... Go with a Borgeson, or RedHead steering box. They actually have a clue on what they are doing on a rebuild.
Old Oct 4, 2015 | 10:53 AM
wv ram's Avatar
wv ram
sounds like you need and intermiditiate steering shaft that's why the u joint is loose on the steering box
