Coil and plugs
Old Jul 12, 2015 | 04:36 PM
Khris1994's Avatar
Khris1994
Default Coil and plugs
Bkr7e-11 is a 43 gap. I should be able to spread it to 45 no problem
Old Jul 12, 2015 | 06:22 PM
UnregisteredUser's Avatar
UnregisteredUser
Yep, that's within range. You won't want a Screamin' Demon behind a gap that narrow, of course.
Also keep in mind that for the vast majority of folks running small block Magnums, upgrading the ignition is of no practical value. If you're not going to be exceeding 7000RPM or doing more than a little bit of low RPM/high load/high elevation (>10,000') work, the stock system is just fine.
Old Jul 12, 2015 | 06:35 PM
Khris1994's Avatar
Khris1994
Well as the original coil is 19 years old and rusty I figured I would go ahead and upgrade. As I may do internals or a cam some day I figured going above stock now wouldn't be bad
Old Jul 12, 2015 | 08:11 PM
beeker's Avatar
beeker
I've got the Davis coil and Livewires too, using cheap autolite copper with .65 gap. Been running great for about 5000 miles. Think I will pull em and see how they look.
Old Jul 13, 2015 | 12:16 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
I've got the Livewire kit with Dist cap, rotor, plug wires and coil. I too was gapping my plugs out to .052 but I don't remember which brand they were. I have not had any issues with it so far.
I am building a 408 right now and we'll see how the Livewire does on the bigger engine. If it has issues I am thinking of trying a 6ALN.
Old Jul 13, 2015 | 05:57 AM
Khris1994's Avatar
Khris1994
Did anyone notice gains when they did the new coil? my full setup for now as I make more money is going to be a 180 stat, flexalite fan, modded kegger, 1.7 rockers, summit exhaust manifold, magna flow cat, Gibson super truck exhaust, high flow water pump. Eventually it'll get new heads with oversize valves, cam (mild probably), and new lifters maybe a stroker kit.
Also: slightly larger injectors and a tune.
So I figure that's why I want to up the coil now
Old Jul 13, 2015 | 07:09 AM
Spillage's Avatar
Spillage
You can see what I've done in my signature... this has gained 4mpg over how it was as stock for its age... I'm getting 14½-15mpg at the moment, which still isn't what I got when it was new (but I have more power than when new, so ....).
I'm still on the original coil, but I don't see a hot coil making that much difference for a non performance build.
Old Jul 13, 2015 | 09:31 AM
Moparite's Avatar
Moparite
If you plan on doing the mods get a MSD6A. You will see an improvement in mileage and performance. Down side is you will replace plugs more often.
Old Jul 13, 2015 | 10:58 AM
Khris1994's Avatar
Khris1994
And eventually I'll put the Hughes intake in as well. In the end I'll look into a MSD ignition setup
Old Jul 13, 2015 | 12:25 PM
Ugly1's Avatar
Ugly1
Howdy sir. This seems counter intuitive to me. In atmospheric densities typically naturally found in survivable climates on Earth I was under the impression ionization voltage goes up with pressure. This would imply the stock ignition should work even better at altitude as a general rule. Doesn't it?
