Height Sensing Valve
Old Jul 19, 2015 | 08:55 AM
gibbo01ram2500's Avatar
gibbo01ram2500
Default Height Sensing Valve
Can I eliminate the height sensing valve on the rear braking system of a 2001 Ram 2500. Mine is all rusted and I am replacing all the brake lines / components. I have found the valve but it is 400 bucks. Do I need it? What effect will it have on the brakes if I do not have it?
Old Jul 19, 2015 | 09:31 AM
Skip it. Even dodge stopped using them, and recommended bypassing them when doing new lines on the rear. (yes, lines rusting out is a common problem. especially right above the gas tank.)
If your abs is working properly, you may notice it engage more on limited-traction surfaces. (gravel, snow/ice, etc.) But, aside from that, no difference.
