Fuel injectors 5.9v8
Old Dec 3, 2015 | 10:13 PM
dodgefan99's Avatar
dodgefan99
Originally Posted by cjantczak
I would love to know how they perform i put the yellow tops in for now sense i have them, there easy enough to change so if i find something better i can always swap em out again haha.
Hey, its been a few months. Got em done, they seem to work good but I'm running too rich. I gotta find out if its my IAT or IAC and then go from there. I do have more throttle response and power but that could just be from the plenum. I'll get back to you next week when my new Mopar Sensors come in the mail.
Old Dec 4, 2015 | 03:15 PM
cjantczak's Avatar
cjantczak
On my 98 Dakota my iat sensor would go crazy an show like -50* F which would cause it to flood out from the computer dumping out to much fuel. I think your map sensor might play some role with the fuel mixture too but don't hold me too it
Old Jan 13, 2024 | 10:49 PM
blaze2150's Avatar
blaze2150
Bosch 0280155703 is a better match @ 241.33cc 12ohm 4pin nozzle EV1 connector vs oem 53030778 @ 243.8cc 1pin nozzle
Old Jul 3, 2024 | 08:51 AM
Mneukirch86's Avatar
Mneukirch86
I see a lot of input about more efficient fuel injectors due to rust I have to look into replacing my fuel rail as well soon so does anybody have any recommendations about a more atomizing fuel injector, and good companies to get from? I’ve bought injectors in the past even refurbished and I’ve always had nothing but problems in other vehicles so I’d like to try to avoid that. I hear it’s almost impossible to help the fuel economy in the 5.9 but I definitely would like to find an injector that could help a little bit on that.
Old Jul 4, 2024 | 08:48 AM
Moparite's Avatar
Moparite
I also have herd about the 4 hole injectors. But to date i have not seen any hard facts to back up the claim. If i was going to replace injectors i would at least get flow matched ones.
Old Jul 4, 2024 | 09:56 AM
So far, I haven't seen anything to indicate multi-hole injectors are any better than stock. Of course, replacing old, dirty injectors, with just about anything that is 'new', should be an improvement. Flow matched though, yeah, that's a good idea. Especially if you do a lot of running in open loop....
From what I have seen, just having fuel sync properly set does the most. The pencil beam stock injectors shoot the fuel at the backside of the rather hot intake valve.... which flashes the fuel into vapor in any event. (not to mention, cooling the valve.....)
