4x4 turning issue
Old Aug 30, 2015 | 05:21 PM
badsilver20's Avatar
badsilver20
New Member
Default 4x4 turning issue
I need some help i have a 1999 dodge ram 1500 4x4 5.2l when i am turning the steering wheel while the 4x4 is on it feels like the front axles are binding up and doesn't let me turn that far left or right. One of my friends she that it could be the u joints but wouldn't it do it when the 4x4 was off two if the u joints were bad. It works great when the 4x4 is off. I have all so jacked up the truck and had the 4x4 on and turned the wheel and it dont bind up it turned lock to lock.
Old Aug 30, 2015 | 06:33 PM
Were you on a high traction surface at the time? If so, that's normal, and you really shouldn't do that. Front and rear wheels follow different paths in turns, hence, they travel different distances.... that puts the driveline into a bind condition. If you are on a high traction surface, and do that to much, things break. NEVER use 4x4 on bare pavement.
Old Aug 30, 2015 | 08:29 PM
badsilver20
New Member
no it does it in the mud
Old Aug 31, 2015 | 07:51 AM
HeikIlm's Avatar
HeikIlm
Originally Posted by badsilver20
I have allso jacked up the truck and had the 4x4 on and turned the wheel and it dont bind up it turned lock to lock.
It won't bind because there's no resistance on front tires. As HeyYou said, when in 4wd there's speed difference between the front and rear axle, and since the t-case has no central diff you feel the jerking motion on steering wheel and it might feel that front is binding. It's more noticeable in 4 low, and short wheelbase is more jerky than LWB.
But check the U-joints, they could bind if they are dry of grease. Although they would make noise in 2wd also.
Old Aug 31, 2015 | 10:42 AM
badsilver20
New Member
I will check them out but like i said if it was grease or bad u joints it would do it all the time but going to check anyway
Old Aug 31, 2015 | 01:29 PM
LoneWolfArcher's Avatar
LoneWolfArcher
My guess is that you were getting more traction than you thought you were. When it happens try going back to 2wd. If you have no issues (ie you can move without getting stuck) then more than likely all four tires were getting traction.
Old Sep 1, 2015 | 01:10 PM
badsilver20
New Member
I dont know its about foot or more of mud
Old Sep 1, 2015 | 02:26 PM
Then you were probably fighting against the mud to turn. Dirt isn't real compressible.
Old Sep 1, 2015 | 03:16 PM
Khris1994's Avatar
Khris1994
They make a higher ratio steering gear box if your having issues off-road.
Old Sep 1, 2015 | 05:28 PM
HeikIlm's Avatar
HeikIlm
Be carefull in the mud, so you don't end up with steering parts like this:
