Shifter won't go into D1 or D2
Old Sep 2, 2015 | 03:07 PM
jf1000's Avatar
jf1000
Default Shifter won't go into D1 or D2
46RE, 1998 1500 4x4 5.9l
Won't shift into D1 or D2 using the shifter. It is like the linkage is stuck or hitting something.
p r n d are fine. The transmission shifts smoothly through All gears when D.
It has probably been years since I tried shifting beyond D. Is there a chance something has rusted frozen?
I looked at the linkage and it is rusty but moves.
Any ideas?
Thanks,
Jim
Old Sep 2, 2015 | 04:30 PM
IHfarmer3339's Avatar
IHfarmer3339
Same on mine!
Old Sep 3, 2015 | 03:49 PM
Shift gates are in the steering column..... Disconnect the linkage at the trans, and see if you can shift the trans down all the way. If that's ok, try the shifter. (still disconnected)
