Fixed plenum. Still smokes?
Old Sep 17, 2015 | 08:53 PM
  #31
MattCooksley's Avatar
MattCooksley
by some chance do you have a vacuum leak at the throttle body giving you a false map reading. Grey smoke with no cat sounds like fuel to me.
Old Sep 17, 2015 | 08:57 PM
  #32
Khris1994's Avatar
Khris1994
Default Fixed plenum. Still smokes?
New throttle gasket. The rich fuel I'm pretty sure is the fouled O2 sensor.
Old Sep 18, 2015 | 08:38 AM
  #33
Put in a new sensor. NGK, or Denso please. Skip bosch. Our trucks don't really care for them. Reset the PCM, and see if some of your problems disappear.
Old Sep 18, 2015 | 09:48 AM
  #34
Khris1994's Avatar
Khris1994
Yea. I was trying to wait for the smoke to drop down some. Im just wondering what's causing the misfire and low compression. But I'll know tonight
Old Sep 18, 2015 | 04:23 PM
  #35
Khris1994's Avatar
Khris1994
Cleaned plugs and new O2. Truck idles on deceleration better. And no smoke anymore. But can someone explain how to burp the coolant better as the truck doesn't seem to want to run at 180. It's sitting at 200 according to my gauge and fluctuates in either direction slightly.
Old Sep 19, 2015 | 10:43 AM
  #36
Khris1994's Avatar
Khris1994
1,5,7 160psi
3 135psi
2,4,6,8 160psi
Cylinder 3 wet test 170psi
Old Sep 19, 2015 | 11:06 AM
  #37
Rings on 3 are going.
Check some of my more recent posts on how to bleed most of the air out of the cooling system.
Old Sep 19, 2015 | 11:41 AM
  #38
Khris1994's Avatar
Khris1994
Yea I figured. That's why I wet checked. How long does it usually take for them to become catastrophic? And I tried doing it to other posts but it doesn't seem to want to let any more air out. I'm going to a buddy later with a live scanner and I'm gunn check what it thinks the temp is
Old Sep 19, 2015 | 11:58 AM
  #39
It may stay that way for years.... or, it might fail this afternoon on your way to your friends. Its a crap shoot. But, worst that usually happens is they just stop sealing, and you end up burning some oil.
Old Sep 19, 2015 | 12:05 PM
  #40
Khris1994's Avatar
Khris1994
I can deal with that. As long as the truck is ok I'm good. I can continue upgrades and repairs
