Misfire monitor
Old Dec 27, 2015 | 05:57 PM
360_magnum's Avatar
360_magnum
I'll give it a shot. New o2 sensor as well.
Old Dec 27, 2015 | 06:04 PM
What brand? Still have your cat?
Old Dec 27, 2015 | 08:45 PM
360_magnum's Avatar
360_magnum
Huges, ya I still have the cat.
Old Dec 27, 2015 | 09:01 PM
Hughes???? They have their own brand of O2 sensor?
Checking their site, looks like they sell NGK, which is what is recommended.... so, so much for that thought.
Check the cap/rotor, and wires. Make sure they all look good. (plugs too.)
Old Dec 27, 2015 | 09:37 PM
360_magnum's Avatar
360_magnum
Oh I thought that you ment the air gap. The o2 sensors aren't bosh. I know dodge hates them. They are ngk, that's what was on there before. I cleared the codes and drove it again, this time the p0307 didn't come back. Just the p0300, p0302, and p0305.
Old Dec 28, 2015 | 07:43 AM
There is a Tech bulletin in the faq section here for plug wire routing, may want to have a look at that too.
Old Dec 28, 2015 | 09:08 AM
360_magnum's Avatar
360_magnum
Ok, I'll look for that. What happens if you don't have them routed right?
Old Dec 28, 2015 | 02:09 PM
Cross-talk. Which translates to misfires/backfires.
Old Dec 29, 2015 | 08:47 PM
dbbd1's Avatar
dbbd1
Which is probably made worse if you have a super-duper ignition coil.
So, has anyone had any luck avoiding this issue with aftermarket plug wires?
Old Dec 29, 2015 | 08:48 PM
360_magnum's Avatar
360_magnum
I have aftermarket ones problem is the same with both setups
