Misfire monitor
Old Feb 22, 2016 | 03:12 PM
  #51
360_magnum's Avatar
360_magnum
If I have it just leak it's normal but if I plug it while it's running it dies.
Old Feb 23, 2016 | 08:29 AM
  #52
Have you cleaned the throttle body?
Old Feb 23, 2016 | 06:40 PM
  #53
360_magnum's Avatar
360_magnum
Ya it's clean
Old Feb 24, 2016 | 02:05 PM
  #54
dapepper9's Avatar
dapepper9
What plugs did you swap in when you changed em?
Old Feb 24, 2016 | 02:54 PM
  #55
360_magnum's Avatar
360_magnum
I have some platinums in there right now. I'm going to change them out for some coppers today.
Old Feb 29, 2016 | 02:58 AM
  #56
360_magnum's Avatar
360_magnum
What would a map sensor that has a semi clogged vacuum connecter do? Just curious.
Old Feb 29, 2016 | 08:27 AM
  #57
Give wrong/slow readings to the PCM, so, fuel mixture would be kinda screwy.
Old Mar 16, 2016 | 11:53 PM
  #58
360_magnum's Avatar
360_magnum
I'm curious why would a dirty throttle body cause a mis?
Old Mar 26, 2016 | 01:29 PM
  #59
360_magnum's Avatar
360_magnum
Ok I got it running like new. Thanks for the help.
Old Mar 27, 2016 | 10:38 AM
  #60
What was the solution?
