Misfire monitor
Old Feb 19, 2016 | 11:40 AM
  #41
dapepper9's Avatar
dapepper9
For *hits and gigs, what plugs did you use? If they aren't copper or just really hot you could very easily have wasted time and money on something simple
Old Feb 19, 2016 | 06:21 PM
  #42
360_magnum's Avatar
360_magnum
The engine was put in last year so I know the compression is good.
Old Feb 19, 2016 | 06:50 PM
  #43
360_magnum's Avatar
360_magnum
I'm wondering vacuum leak or even computer
Old Feb 20, 2016 | 07:44 PM
  #44
360_magnum's Avatar
360_magnum
So what it's doing is, when I first start it, it runs ok with the rpms higher and it starts to miss when it goes to idle. I don't feel it when I'm at higher rpms just the lower ones.
Old Feb 21, 2016 | 10:30 AM
  #45
Still the original injectors?
Old Feb 21, 2016 | 02:22 PM
  #46
360_magnum's Avatar
360_magnum
Ya same part number
Old Feb 21, 2016 | 07:53 PM
  #47
360_magnum's Avatar
360_magnum
Ok so I hooked up my scan tool and I noticed it was staying at negative 10 fuel trim
Old Feb 22, 2016 | 11:47 AM
  #48
So the PCM thinks the engine is running typically rich. How old is the O2 sensor?? and what brand?
Old Feb 22, 2016 | 12:14 PM
  #49
360_magnum's Avatar
360_magnum
Ya when I saw that and for kicks I unplugged the pcv and it ran like normal. I think it's ntk or ngk one of those and they are only a couple months.
Old Feb 22, 2016 | 12:28 PM
  #50
Did you block the vacuum line from the PCV? Or just leave the vacuum leak?
