differential rebuild, what do I need?
Old Oct 4, 2015 | 04:16 PM
That's would I would be concerned about. If one of those let go on the highway..... Well, that would be far more pucker-factor than I would really care to think about.
Old Oct 4, 2015 | 08:19 PM
Erik P's Avatar
Erik P
Hahaha thats true HeyYou. I would love to replace the rear axle but finding one is hard around here for some reason... maybe one day.
Found the source of the rear end noise. What do you guys think? looks like spalling? this is the rear pinion bearing, maybe got to hot and insufficient lubrication?Name:  image_zps0rqmsxfu.jpg
And of course found a broken clutch plate spring....Name:  image_zpsm6ucjctr.jpg
Old Oct 4, 2015 | 09:09 PM
oxymoron29's Avatar
oxymoron29
Holy. Hell. That must have made a racket. And I thought mine were toast.
Old Oct 4, 2015 | 09:32 PM
Erik P's Avatar
Erik P
yeah that sure was the worst race I've ever seen....
Old Oct 5, 2015 | 10:14 AM
I can see how that might be just a bit noisy.......
Old Oct 5, 2015 | 11:05 PM
Erik P's Avatar
Erik P
Well she's all back together and appears to be driving well. I guess we'll see how long she lasts. I took my time setting it up so I think all will be well. Gear pattern came out pretty good but I was concerned about backlash. Before tear down backlash was .012", should I have kept it at that considering the ring and pinion have worn together with that backlash?
Old Oct 6, 2015 | 09:34 AM
What is it now?
Old Oct 6, 2015 | 02:00 PM
Erik P's Avatar
Erik P
What is it now?
I set it at the loose end of the spec from the manual I was using, 0.008". But now I wonder if should have left it at 0.012...
Old Oct 6, 2015 | 03:51 PM
Should be ok. Consider some of your backlash was from wear. Don't think it'll be a problem.
