Suspension
Old Oct 10, 2015 | 05:42 PM
  #21
Khris1994's Avatar
Khris1994
Idk if I will be switching to dual stabilizers as the single seems plenty for me. Also moog has a kit apparently for steering rebuilds in case anybody didn't know. I was looking as I need to do uppers and lowers on mine. Anyone have an opinion towards a drop pitman arm? With only 3 inches I should be fine? It doesn't currently have one as far as I know
Old Oct 11, 2015 | 05:22 PM
  #22
Ramman18's Avatar
Ramman18
Got a link to the Moog "kit"? I don't feel like searching the great web....ha
No, you don't need a "drop" pitman arm. Back in the day, companies were split when it came to supplying this for just 3" lift. Kits varied greatly across the board. Since Skyjacker was one of the kits that did NOT supply it, I left it stock. Anyways, the reason I call it "drop" in quotes is because it just has a reverse taper meaning the tie rod attaches on the bottom instead of the top. This lowers the angle of the TE about an inch or so. For medium lifts (5+) it is definitely recommended and big lifts (7+) you'll need a true drop arm that is much longer.
Old Oct 11, 2015 | 06:04 PM
  #23
Khris1994's Avatar
Khris1994
http://www.moog-suspension-parts.com...packagedeal142
Old Oct 12, 2015 | 02:32 PM
  #24
Ramman18's Avatar
Ramman18
That's the Y-style. I'll be getting the T design for the 98-99HD.
Old Oct 12, 2015 | 03:47 PM
  #25
Khris1994's Avatar
Khris1994
You mean this kit than... http://www.moog-suspension-parts.com...packagedeal015
My only question is do the ball joints fit on the 1500 or do we have to get different tie rod ends?
Old Oct 13, 2015 | 11:29 AM
  #26
Ramman18's Avatar
Ramman18
The TREs will fit until 2000 as the taper was changed. Ball joints for a Dana 60 are larger than the Dana 44 so they will not fit.
Old Oct 14, 2015 | 01:47 PM
  #27
dapepper9's Avatar
dapepper9
I wouldn't install moog on my truck if somebody paid me. They went from probably about the best to one of the worst. Thank you China.
Old Oct 14, 2015 | 04:05 PM
  #28
Khris1994's Avatar
Khris1994
As long as the tre fits in the taper I'm good. How did dodge fix the angle of the track bar for the suspension swap in 98? Is there a factory fix or is it those expensive new mounts and bar?
Old Oct 15, 2015 | 11:23 AM
  #29
Ramman18's Avatar
Ramman18
There was no suspension change in 98. Only the end links for the sway bar got a better mount. The track bar fits 95-02 trucks all models. The first year 94 trucks had a different bolt or something. For 3500 trucks, they got a T style steering in 98 and 99 but not 2000. Brakes were also upgraded in 2000.
Old Oct 15, 2015 | 11:41 AM
  #30
Khris1994's Avatar
Khris1994
Alright. Thank you
