No dome light or headlight/ key buzzer
Old Oct 2, 2015 | 10:13 PM
evilemokid94's Avatar
evilemokid94
Default No dome light or headlight/ key buzzer
Hey guys, I just got this truck last week and iv been trying to figure out why I don't have a dome light or a headlight, key, or door buzzer since I got the truck, neither door turns the light on, I put a new bulb in, and the head light switch doesn't even turn it on. I popped the driver side panel off and didn't see a fuse but I went ahead and check them all and they all look good. Where else should I look
Old Oct 3, 2015 | 10:14 AM
IOD fuse in the side of the dash. It's cleverly concealed by a plastic cover.
Old Oct 3, 2015 | 09:25 PM
evilemokid94
I checked the fuse and the only fuse out is my 20a cig fuse. Iod fuse is good. I noticed that my door jamb switch was broken so I swapped it out with my passenger side and I have the buzzer and chimes back but still no dome light
Old Oct 4, 2015 | 09:24 AM
Need to find out where you are losing power..... Got a volt meter?
Old Oct 5, 2015 | 10:48 AM
evilemokid94
iv got power to one side of the connector ,the other side I have nothing which I think is my ground side but when I put a bulb in I still get nothing
Old Oct 5, 2015 | 11:22 AM
Which connector?
Old Oct 5, 2015 | 11:04 PM
evilemokid94
Which connector?
dome light connector that the bulb goes into.
Old Oct 6, 2015 | 09:35 AM
Switches and such generally provide ground path. If you don't have it yet, grab the service manual for your truck from here. Have a look at the wiring diagrams.
Old Dec 9, 2015 | 07:34 PM
Bwally1996's Avatar
Bwally1996
I've got similar problem, I have the buzzer, but no interior lights, or key light. Fuse is good
Old Dec 9, 2015 | 08:21 PM
dbbd1's Avatar
dbbd1
Prob the CTM.
