Intake Manifold Won't Budge
Old Oct 4, 2015 | 12:51 AM
Monroe00ES's Avatar
Monroe00ES
Default Intake Manifold Won't Budge
So while attempting to remove my IM, the front two bolts (one on each side) snapped right off.
From what I can tell from the other bolts I removed, there are no threads on the IM itself, and it only threads into the block...Is that true?
I attempted to pull up on the IM, and it doesn't even budge a millimeter.
I know on some vehicles (Camaro comes to mind) they have a pry point to break the intake manifold loose. Does the 5.9L have a pry point like that?
I was hoping to pull the IM straight up, and then remove the broken bolts with vice grips, instead of having to drill them down - I don't want to accidently mess something up.
Any suggestions would be greatly appreciated!!
Old Oct 4, 2015 | 01:19 AM
Monroe00ES's Avatar
Monroe00ES
Update - I've been able to get the back portion to lift up slightly, but it appears to hit the head covers.
Do these need to be removed to remove the IM?
Front portion, where the two bolts broke off, still wont budge...
Old Oct 4, 2015 | 09:11 AM
Khris1994's Avatar
Khris1994
Did you remove the alternator bracket?
It clears the valve cover. I recently removed mine
Old Oct 4, 2015 | 09:20 AM
Yep, alternator, and a/c compressor need to be out of the way, as does the bracket. Then you can pry a bit to get the manifold to break loose.
Old Oct 4, 2015 | 01:55 PM
Monroe00ES's Avatar
Monroe00ES
Everything is removed including the timing cover still.
Im guessing the IM gasket was headed towards failure. The portion of the bolts that did not thread into the block were pretty heavily covered in black gunk on some of the bolts, but not all.
The front left side is now moving up about enough to fit a credit card under it, but the right side isn't budging. The bolt on the right side broke off closer to the head of the bolt than the other side.
Im about to go pick up a set of easy outs to give them a try. I'll let you know if it works...
Old Oct 4, 2015 | 02:16 PM
Khris1994's Avatar
Khris1994
Just do a sweep and check all the bolt holes as it should freely come off if the bolt isn't holding it. I pulled a junkyard one and it came off freely with 3 broken bolts in the block
Old Oct 4, 2015 | 04:13 PM
The bolt holes crud up because of different metals being in contact. Acts a lot like cement..... Just put a pry bar under it where you can get some leverage. Shouldn't take too much pressure to get it to break loose.
Old Oct 4, 2015 | 10:13 PM
Ham Bone's Avatar
Ham Bone
You probably just need a big flat head screw driver. Not much can't be fixed by a BFH and a good solid flat head.
If the bolts broke off toward the front, you'll need to pry as close to them as possible and also straight up. Otherwise you will just fighting against the bolt bending from the twisting.
Don't be afraid to smack it with a rubber hammer or something similler to knock it loose from all the crud.
