Manual transmission for 318 v8?
Old Oct 4, 2015 | 02:14 PM
Ro$$'s Avatar
Ro$$
Default Manual transmission for 318 v8?
For 5.2 L (318 cu in) Magnum V8 whats the manual transmission that fits without any modifications? 5-speed NV3500 manual 5-speed NV4500 manual 6-speed NV5600 manual any other?
Old Oct 4, 2015 | 02:19 PM
Khris1994's Avatar
Khris1994
Should be the nv4500. There are a couple if other post
Old Oct 4, 2015 | 04:12 PM
It came with the 3500 behind it. 4500 will bolt up in the same spot. Not sure about the 5600....
Old Oct 4, 2015 | 04:16 PM
Spillage's Avatar
Spillage
NV3500 - 1500 and 2500LD Rams.
NV4500 - 2500HD and 3500 Rams.
NV4500HD - V10 and diesel models.
NV5600 - 99-00 Rams, and the only trans behind the H/O diesel in 01-02.
If swapping trans, check the input and output shafts, to make sure they match.
Old Oct 4, 2015 | 08:47 PM
Ham Bone's Avatar
Ham Bone
NV5600 wont work. Different bellhousing.
Old Jul 21, 2022 | 10:19 AM
S H's Avatar
S H
Np435 will give you granny low or even a t18 or t19 will also if you can find them Eaton 10spd isn't too much modifying either as far as I know
