Wiring Help Needed
Old Oct 13, 2015 | 06:08 PM
PAwrestling#1's Avatar
PAwrestling#1
All the fuses good in side dash also
Old Oct 13, 2015 | 06:44 PM
Check for power at the switch.
Old Oct 13, 2015 | 06:51 PM
PAwrestling#1
Driverside i have one wire with power. Green and yellow i believe. Passenger side nothing
Old Oct 13, 2015 | 07:10 PM
For the windows, the tan wire should supply power.
For the locks, should just be the red wire.
Old Oct 14, 2015 | 07:06 AM
PAwrestling#1
After going out and rechecking before work this morning the wire is tannish brown. The green is a little over spray.. hahaa.. And there is power there. THere is also power to the red wire on door locks on drivers side. I couldn't get anything over on passenger side tho. Does the switch on drivers side feed passenger side, does it have to be hooked up and operating properly? But back to drivers side, is it the switch or bad socket? It seems like there might be a little play in the metal rings down in the holes of the socket maybe isn't making connection to the prongs of the switch?? How do you test the switch? Can you? THere was issues with these when we bought this truck, passengerside switch for window didn't work at all and to use the drivers side switch for passenger side window sometimes you had to mess with that switch to get it to work.
Old Oct 14, 2015 | 10:58 AM
Dirty contacts in the switch can cause your issues. For the windows, the drivers side switch does indeed provide the power to the passenger side switch. May be able to simply replace the driver side, and have things start working.
Old Oct 14, 2015 | 06:07 PM
PAwrestling#1
everything fixed and I thank you all..
Old Oct 14, 2015 | 08:18 PM
What was it?
Old Oct 14, 2015 | 09:38 PM
PAwrestling#1
id rather not say... hahahaha
Old Oct 15, 2015 | 11:34 AM
Oh come on. Don't leave us hangin' here. Not like the rest of us have never done anything silly.
