heavy gas smell in oil, oil residue in plenum, loss of power and mpg
So I know the latter symptoms point toward the plenum gasket failing, but haven't seen gas in oil reported. Changed my oil today and it reaked of gas. Pulled the air cleaner and noticed residue, fairly fresh looking. And I haven't owned a 5.9 gasser in years, but the power seems a bit down, and I've only gotten about 124 miles on 5/8 tank of fuel, which seems a bit low. The truck has 170k miles, new 4.10s and 285s, plugs, cap, rotor, air filter, etc
Plenum went bad. Most likely took the front o2 with it. Thus, dumping to much fuel into the cylinders. Hence your poor gas mileage. (Recently had the same issue with the o2) The fuel smell in the oil? Maybe try a compression check to make sure your rings are sealed and the excess fuel isn't dumping down a bad ring instead of sucking oil up? Maybe try changing your timing chain as well if it wasn't done previously as I hear they stretch good by 150k. I'm doing mine real soon...
that is no bueno. Current plan of action is to test compression ASAP, and if I still have ok compression get the plenum fixed. If the cylinders don't have good compression, and it's looking like a rebuild, it's time to start ordering the parts for a 4bt swap. Cause if I need to pull this gasser out, she's not going back in
Just did the oil change today, so I will disconnect the sensor and then wait to do the test. I'm assuming I will just run lean?
Trending Topics
I've actually been reading about them a bunch already, in plan to do one at a much later date. But if that date needs to be moved up, that's all there is to it lol. This will be my 5th 2nd gen ram, the others were all 12v and 12v trucks and loved them to death. But the 6bt is just a bit much for these 1/2 frames and the 4bt will be a torquey little motor and provide great mpg
