Oil pressure
Old Oct 14, 2015 | 09:09 PM
Jays's Avatar
Jays
Default Oil pressure
When the engine is warm and i stop at a stop sign the oil pressure light comes on. But if I put it in neutral or park light shuts off....????
Old Oct 14, 2015 | 10:28 PM
primem's Avatar
primem
the engine idles faster in park and neutral so the oil pump output is higher.
you could put a master gauge on the engine to verify the oil pressure. if it confirms low oil pressure, the oil pump may be worn out or the engine may be tired/xs bearing clearances.
if the pressure is ok, the sending unit may be nfg.
Some people run a higher viscosity oil.
go blue jays
Old Oct 15, 2015 | 11:03 AM
schmidtp's Avatar
schmidtp
I would start with a new oil pressure sensor since they are known to fail, if you still have the problem then try a new high flow oil pump, pickup screen, and oil pan gasket.
Plenum fixed?
