no lowbeam passenger side
Old Oct 15, 2015 | 01:24 PM
fetzer's Avatar
fetzer
Default no lowbeam passenger side
i have a 2000 ram 1500 with no low beam lamp on passenger side. fuses are good and both 12v pins test good at socket, but no ground on center. high beam works both sides. any ideas?
Old Oct 15, 2015 | 01:52 PM
Dual or single bulb? (sport model?)
Old Oct 15, 2015 | 01:57 PM
fetzer's Avatar
fetzer
it is a single bulb on each side.
Old Oct 15, 2015 | 02:23 PM
BigGreenRam's Avatar
BigGreenRam
Try a new bulb
Old Oct 15, 2015 | 02:38 PM
fetzer's Avatar
fetzer
of course i tried a new bulb. with no ground at the harness the bulb is not the issue
Old Oct 15, 2015 | 03:30 PM
Flue's Avatar
Flue
Had the same problem on the Drivers side, ended up cutting the wire and re-connecting...ground is spliced (on mine anyhow) on the side yellow (running lights?) that was all rusted. With very limited elbow room, I just cut the ground wire and spliced in a new ground source. Low and High is back on par.
