high idle low idle
Hey folks having another problem with the big and dumb. (99 ram) with a 360 motor.
here is what I have replaced so far.
MAP, Throttle body, IAC motor everything bolted to the TB is new and both 02 sen.
and still get the problem when it sits awhile. (no set time) it will idle up maybe 2 to 300 prm or go down to 2 to 3 hundred rpm and even die a few times.
It runs great and gets pretty good mpg never tried to die while moving.
An ideas will be welcomed.
hello hy
I am having a issue with battery drain that I cant trace yet. and disconnect the battery daily because of this. but didn't think that would have anything to do with the idle problem but again im not a mechanic either. But the alternator is new and charging. I have duel batts.
a side note that may help. say I drive the truck 30 miles and do not disconnect the batt and turn the truck off then a few mins later restart it the engine light will come on (most of the time not all) and the weird idle will start then also if I sit and idle for awhile.. and I cant think of the code it throws but ill test it later and post it here.
but as far as engine running no. it runs real smooth and quite until the problem starts I`m normally early for work and I`ll sit there idling for as long as 30 mins then the surging may start or may not start but doesn't throw any codes while idling if I do not shut the truck off. If it starts the idle thing I just give it some gas and it runs fine for awhile, if I keep it say 2000 rpm it wont do it.
I have replaced all those parts listed above and it still does this.
my brother in-law said to have my fuel pressure and system checked also, may be a bad injector?
is there any fuel sensor stuff on the motor near the fuel rail area?
I just thought of something, when it starts the weird idle thing it starts smelling real rich, I mean burn your eyes rich.
See what code it is coming up with, that may be enlightening...
By disconnecting the battery when you park, you reset the PCM each time you do so. The PCM then has to relearn how to run the engine. That may be a part of your problem.... or, it may be something entirely different. (we havin' fun yet?
Need to sort out your battery drain first I think, and see if the other problems don't then go away. These trucks behave rather strangely if the electrical system isn't up to snuff.
) Need to sort out your battery drain first I think, and see if the other problems don't then go away. These trucks behave rather strangely if the electrical system isn't up to snuff.
Welll i think i fixedthe idle problems i replaced the pcv val e on the al e cover and the problem went away,BUT im not getting y hopes up yet i didnt have a chan e to take it onn a test dribe either so we will see tomorrow when i go to work hey you, i got that code and forgot where i wrote it down! Ill get that tomorrow to dam i hate geting old
I had time to work on the booger, and Im still having the idling problem but.
in another forum here I listed my trans problems. and im begeinign to think its all related. here's the problems
1 Hi/low idle
2 codes P0753 (2nd gear trans relay) and p1765 show up after resetting the comp, so I jump out the 0753 code (really) and have no problems and drive it daily, everything is new in tranny. not sure but I think both of these codes come from the same area.
3 battery drain comes from the tranny really, when I jump the tranny relay the drain starts, when I put the relay back in the parasitic drain stops.
I just have a sneaky suspicion its my PCM. aarrgggg!
1 Hi/low idle
Trending Topics
Is the relay control shorted to ground?
Only one trans relay. It supplies 12 volts for the O/D, and TCC solenoids. Governor pressure stuff gets everything direction from the PCM. (I think.)
Pull the relay, stick one probe from your meter in the ground side of the relay control circuit, and the other probe to a good ground. See if there is continuity. (or zero resistance, if your meter doesn't do continuity testing.)
