Truck shakes bad
Old Nov 12, 2015 | 04:56 PM
Do you have LSD??? (limited slip diff.)
Old Nov 12, 2015 | 11:52 PM
sam3293's Avatar
sam3293
Yes LSD
Old Nov 14, 2015 | 10:19 AM
Change the fluid in the rear, and make sure it has the proper amount of additive for LSD.
As for the 'shakes over bumps'...... I am just not sure what's up with that.... Could be a loose connection somewhere, the presents itself when you hit a bump. (perhaps that number 4 injector connector?)
Old Nov 15, 2015 | 02:12 PM
sam3293's Avatar
sam3293
Ok so i replaced the extension housig seal on t case and the seal for the rear axle driveshaft in differential. The pinion yoke nut was loose. I tightened it the best i could but i doubt i hit the 210 ft lb mark. Any ideas how to tighten it up im havig trouble keeping the differential from spinning.
Old Nov 15, 2015 | 10:58 PM
Impact wrench.
Barring that, have someone step on the brakes.
Or, use something long enough, that will hold the yoke in place, and brace it against the ground.
