Help me!!! Before i set fire to my truck!!!
Old Nov 12, 2015 | 08:02 AM
ramsportrocks's Avatar
ramsportrocks
spend the extra and get an OEM or Denso if you plan on keeping the truck for a while
Old Nov 12, 2015 | 09:32 AM
dapepper9's Avatar
dapepper9
^^Delphi is the brand you want. Least troublesome and OEM. Fuel pressure should be 49+/- 1psi according to the 2001 fsm
Old Nov 12, 2015 | 04:54 PM
Delphi or Denso. Do NOT bother with airtex......
Old Nov 12, 2015 | 05:26 PM
midnight_f150's Avatar
midnight_f150
Thanks for the parts suggestions. My buddy is letting me borrow a fuel pressure gauge. Will test that on my next day off and if it checks out I will move on to the crank/cam sensors.
Old Nov 12, 2015 | 07:11 PM
Pkm10950's Avatar
Pkm10950
Default Vacuum leak?
Check for a vacuum leak or bad crank sensor.
Old Nov 13, 2015 | 07:37 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Agreed, Delphi or Denso. I put a Delphi on my truck.
Old Nov 23, 2015 | 12:56 PM
midnight_f150
Test shows 45psi at idle. It jumps up to 50psi and holds when I rev it up 2000rpms drops back down to 45psi when returned to idle. When shut off it drops to 35psi. When you click the key back to run the pump kicks on and psi jumps right to 45psi again. Any help suggestion my next move would be great.
Old Nov 23, 2015 | 10:38 PM
69_XS29L's Avatar
69_XS29L
What is the fuel pressure when the truck is acting up is part of the point these guys are trying to make.
Old Nov 24, 2015 | 03:11 AM
zildjian3707's Avatar
zildjian3707
your fuel pressure is ok, could be a bit higher, when my fuel pump was taking a dump it would start but the truck would die as soon as i started backing up or put it in gear sometimes. If its having trouble idling i would check the IAC and MAP sensor and work your way to the cam sensor.
