driverside brakelamp/turn signal
Old 11-11-2015, 02:16 PM
CrimsonTide1500's Avatar
CrimsonTide1500
CrimsonTide1500 is offline
Default driverside brakelamp/turn signal
I am wondering if this is a wiring issue or something, but my turn signal and brakelamp went out the other day, yet the running light is still functional.
Checked the fuses, they look fine, the front turn signal is functional.
Any ideas? I was thinking maybe flasher, but that doesn't seem like it would control the turn signal and the brakelamps
2000 Ram 1500 Sport
Old 11-11-2015, 02:43 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,383 Likes on 3,123 Posts
I think the turn signal, and brake lamp are the same filament in the bulb, running lamp is separate, try changing the bulb.
Old 11-11-2015, 04:57 PM
CrimsonTide1500
Sorry, forgot to mention that I had changed the bulb and the issue is still there.
Old 11-12-2015, 04:55 PM
HeyYou is offline
Check for power/ground at the socket. If you have a trailer harness, check where it hits the rear harness. They are notorious for causing issues.
Quick Reply: driverside brakelamp/turn signal
