Hard brake pedal
Figured out the brake light issue. Must of bumped the e brake when I was under the dash. So that's off. But I'm still not sure about how stiff the pedal is. Line is hooked up on both ends and it's a reman booster and a new master cylinder so I'm not sure if it's just that's it's so new I, not use to it or if there's air in the system or what
A new booster should give you a pedal that if you look at it the wrong way, your brakes apply. Should take very little effort to get some serious braking. Air in the lines will make the pedal spongy. Rear brakes out of adjustment will yield a pedal that goes down a long way before you actually start getting any braking action.
Verify that you are getting vacuum AT the booster end of that line. If you are, I would highly suspect a bad booster, as it sure sounds like you aren't getting any vacuum assist there.
